Which Clutch?
Old Feb 9, 2011 | 03:56 PM
beltrame02WS6's Avatar
Default Which Clutch?
Clutch is pooched and I now need a new one, just dont know which one to buy. Also not sure if I need to purchase any other components such as a flywheel?
Car:
2002 WS6
M6
lid
Pacesetter long tubes w/ ORY
Magnaflow Cat Back
Was thinking about a Centreforce II?
Old Feb 9, 2011 | 04:25 PM
RARON455's Avatar
If you plan on modding the car, a stock clutch will never cut it, alot of guys run the LS7 some have good luck, some have bad. I run a monster level 4 behind my 383. A ton of guys run monster clutches and love them, and their customer service is second to none. I would stay away from Spec clutches, I have heard way too many horror stories about them.
http://monsterclutches.com/gm.html
Old Feb 9, 2011 | 05:00 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Look at the LS7 setup, I've had two and have no complaints
Old Feb 9, 2011 | 05:07 PM
Only reason I say Centreforce is because I can get killer deals on them. Dual Friction Centreforce for $450
Old Feb 9, 2011 | 07:50 PM
southernculture's Avatar
I have a spec stage 2 with billet steel flywheel for 300 shipped. It is brand new. Shipped from spec direct. It is good for 690 ftlb of tq and retails at 429 plus shipping. I am selling because I thought there was a problem with the clutch so I sent it to spec and went a different way. Ended up being a different issue now I have a clutch I dont need. It is 300 for the clutch flywheel pressure plate alignment tool and the slave shim. This will also be shipped from spec themselves. If you are worried about the product contact spec 01 direct I have many contacts with him about this clutch. I also can promise it has 0 miles on it!
