need some ls1 advice for future engine
Old Feb 7, 2011 | 10:52 PM
ram air camaro's Avatar
Default need some ls1 advice for future engine
i have a 2000 z28 a-4 ls1 and it has 137k on it and i plan on fully doing a bolt on first (including cam) till it goes to heaven but my question is what is the best engine replacement for the ls1 block to go all out on like a 396+ ci motor ??
just tryin to see if i can start lookin for a replacement block at a good price i been hearing lq9 allot can anybody explain to what car that comes from so that i can find it at a junkyard
should mention this car wont be my daily driver just a weekend warrior
Old Feb 8, 2011 | 11:01 AM
majeskyb's Avatar
You can drop a ls6 in if you want. They're pretty reasonably priced, but I'm guessing you can't bore it over too much like you can't on the ls1. From what I've read they're a direct drop in- PCM works fine with them, and pretty much any part that'll work on your stock engine will work on it.
Old Feb 8, 2011 | 11:17 AM
BStowers023's Avatar
any GM truck that comes with the 6.0, so like your denali's and 6.0 silverados and sierras. You might be able to find one in a junk yard but honestly you can get a LQ9 or LQ4 longblock for well under a grand that runs good.
Old Feb 8, 2011 | 06:27 PM
Orange Juice's Avatar
These days it seems as if there is a block for every budget and build. Do you want iron or aluminum? Your goals sound a lot like mine when I wanted to upgrade from a H/C setup. If you want to feel the rear end break free in 3rd gear just go for the cubes.
