h/c questions
Well the best heads are probably gonna be some worked afrs or trick flows, If your budget allows. If everything is set up right it should handle the spray fine, Now if your running the stock bottom end, that may be a whole nother issue.
If you have the MS4 I would recommend it on a 111 LSA. How much nitrous are you looking to spray? The MS4 can handle a decent amount but if you are spraying more then a 200 shot typically we will spec more towards the nitrous at that point.
