Service Vehicle light won't turn off...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Thanks!
-Blake
if the light is still on there is still a fault present.. if the o2 sensors were bad, and some one changed them out but did not clear the code, the code should clear itself in a bout 100 miles.. go to autozone, and get the car scanned for DTC's, then post up what codes are in your car... and post the codes.. theeenn we can help
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If it's the service Vechicle soon light, then it won't have anything to do with you emissions (in other words, it's not your 02 sensors). It could be anything from problems with your abs to (from what I've heard) a burnt out bulb. You need to get it scanned.
you can try to disconnect the neg cable on the battery for a min or to then reconnect it. that will reset everything. then if it comes on you know you still have a problem. Gm vehicles may take a few time of driving the car and turning it on and off before it kicks on again. if it does.
It's already been scanned with a Tech 2 and there isn't a single BCM code, yet the light is still on. The only thing I can think of is that since this car was a V6, and it was swapped with an LS1 about a year ago and the light has been on since then, that that has something to do with it. It's just weird that there are no codes, but my Service Vehicle light is on. And I know it's not emissions, those have all been cleared and fixed. I am having braking problems (under hard braking I experience a "notchy" feeling in the pedal) but I am still not throwing any codes-but maybe somehow it is related to an ABS problem.
