Torque Specs for PRC 5.3l 2.5 heads?
LS1Tech Premium Sponsor
Agreed, the heads do not change the specs. if you're using GM bolts you can use the specs found on LS1howto.com, or if you have ARP bolts or studs they come with their own torque value.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
