Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firebird How to Replace Air Filter<br>Step by step instructions for do-it-yourself repairs.
K&N air filter really that good?
#41
Yeah, because a $6 filter every 6 months is gonna kill my mod budget. I'd rather not deal with dirty, oily air getting into my engine and spending $6 twice a year, and not dealing with having to clean a dirty, oily, disgusting K&N. I've run them before in other vehicles, and I never will again.
#42
Just threw mine in the garbage last week and dropped in a paper Fram. My lightly oiled K&N was still soaking the MAF sensor wires and causing issues, don't have to worry about that anymore!
#43
Then don't run one. Easy as that.
I beg to differ on the exhaust though. So I guess there's no difference in 1 3/4" and 1 7/8" primaries?
I've SAVED money by buying one simply b/c I don't have to waste money on paper. I don't see how the #'s would be purposefully skewed. Plenty of independent graphs out there from people other than LS1's prove otherwise.
I really see no reason NOT to use one.
Let's agree to disagree.![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
** On a side note though, if AEM would ever get off their lazy *** and make a dry flow drop-in panel filter, I'd be the first in line.
And Sure 1 3/4 and 1 7/8 with produce different results because it has not maxed out their efficiency. My example of the stock car with a 3 inch pipe vs a 5 inch pipe was meant to show that on a stock car the 3 inch pipe will flow more then enough to maximize power. So adding a 5 inch pipe will not change the numbers. Its not like just because there is more flow possible out of the pipe that the exhaust is magically going to appear. The engine itself can only produce so much exhaust. just like the engine can only take in so much air.
#47
http://www.youtube.com/watch?v=aKKn38nmXtg
I went to a convention one time, and they had a setup with every major brand side by side to compare air flow similar to this test, k&n being the best flowing. It is expensive, but it is reusable, has a nice warranty, looks good, and i think the design of the filter is superior.
With that being said, you can't go wrong either way cuz all a air filter is suppose to do is filtrate the air, the k&n does a good job, but not the best job, in that department. However, my MAS is clean so im happy![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
I jus like knowing my air filter flows really well, looks great in the engine dress up department, and is reusable
I will emphasize on you can't go wrong with going with a fram over a k&n
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#48
The Scammer Hammer
Bull. ****. If a filter flows more are, physics dictates that it must have a more open cell structure. K&N isn't breaking physics; if their filters allow more air to flow in, then more dirt also gets in. Just because you've personally seen a few examples of clean engines with K&N filters doesn't mean anything; I doubt any of those LS1 cars saw anything but street duty. Ask anyone who offroads regularly; K&Ns are great for allowing a whole lot of dust into the intake.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
All I'm saying is I like MY fiter. I know HOW to oil it, I know HOW to take care of it, and Ihave NO problems with MINE.
I like the AMSoil filter, but I'd like to be able to wash it, and they reccommend against that. Again, wish AEM would make a panel filter.
This wasn't suppossed to turn into a damned pissing contest. I'm just stating what I have seen; that isn't BULLSHIT.
#49
I'll remember this next time I take the SS out on the dirt track....![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
This argument comes up every single time with K&N; why people think that damn filter is magical constantly eludes me. It is a coarse-weave cotton filter; it is going to let more dirt in. End of story. "But you can run it longer than a paper filter before it gets dirty enough to need cleaned!" Why? Because it's not trapping as bloody much dirt.
K&Ns filter like ****, and do absolutely nothing to remove paper air filter "restrictions", because paper air filters aren't restrictive. If people want to use one to justify not spending $6 every few months on a paper filter, fine, but the whole "K&Ns flow and filter better than paper filters, and increase horsepower" **** gets old, especially since it's repeated ad nauseum every single time the topic rolls around.
#50
a few guys in the silveradoss.com website got together with a dyno and put to test some of the common cold air intakes for the silverado ss. One of the intakes that they tested was the K&N. This is an unbiased opinion with results from the intakes on the same truck. http://www.silveradoss.com/forums/to...-wars-results/ Obviously this is not your ls1 but it gives a reference on an ls based motor.
#51
Search for K&N on bobistheoilguy, pretty much anyone that ran a K&N filter had excessive silicon levels in their oil analyses. Or continue to believe that a filter that doesn't even fit your vehicle without a POS gasket that you can see pinholes through filters just as good as a real filter.
Here's another test but it must be marketing to even though none of the filter companies had anything to do with it.
http://www.autohifidiszkont.hu/bmw-t...szuroteszt.pdf
#52
#53
As much as I hate to even contribute anything to one of these debates (Who knew that air filtration fell into the same category as religion and politics?), I do have one personal data point to add. My previous car was a 2006 Dodge Magnum R/T. These vehicles have a "hidden" diagnostic mode that shows real time rpm along with a bunch of other useful/useless information. After installing a K&N 63-1114 CAI system (cone filter) I was recording just over 300 rpms less when cruising at 65 mph. Thus, the engine was not working as hard with the K&N filter. The added noise from the CAI contributed to the butt-dyno perception that the car was a bit more powerful. The "power sensation" increased, but I can not confirm that there was actually any improvement from the filter itself since I never had the car dynoed. My mpg did not change from the CAI.
Later on I installed a Diablo Sport Predator tuner on the Magnum. The tuner for the Hemi engines has a tune for 91 and 93 octane and each octane tune is split into two seperate tunes...with CAI and without CAI. Which leads me to question the conspiracy..."Is Diablo Sport secretly working with K&N, etc., on the whole concept of better air flow by using their filters to produce more power?" Regardless, the Predator made a world of difference in the 5.7L Hemi engines. And the CAI played its role in that difference.
Granted that this has nothing to do with an LS1 powered vehicle in any manner, but the arguement of filtration and air flow seems much more general than a vehicle specific application. My spin on the whole discussion (and for some, arguement) is that the real benefits of a K&N, etc., filter vs. a paper filter will be vehicle, model, and trim level specific. In general, if the intake system in your vehicle is poorly designed, a "high flow" filter will likely gain you something on its own. If, however, the intake system is design well, as it is in the LS1s, a "high flow" filter will not gain you anything by itself. If you go beyond a stock motor or tune for the "high flow" filter, you are changing the parameters of the discussion and your results can vary significantly.
At the end of the day, it's just a filter. Are we really arguing about the potential gains of 5hp, maybe 10hp, (before losses) and possibly 0.5mpg? You'll loose more mpg just sitting in stop and go traffic! If you like it, buy it and drive it.
FWIW, I just purchased a used K&N for <$30. Flame on...
#54
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#56
The Scammer Hammer
Element, get off your ******* high horse.
This wasn't suppossed to turn into a damned pissing contest, as I STATED ABOVE. All I'm saying, is my PERSONAL views. I like them, I run them, I have in 5 F-body's, and my DD's (limited experience?). I've had NO issues with them. I'm not insinuating that my experience should be the baseline for ****. I'm simply stating MY experience. OP came in here and asked for opinions. We each gave ours.
You don't like them. Fine. You feel they let more dirt in... fine. I get that. We've both said our piece. Leave it at that. OP is going to make his own decision, and likely already has. (They do indeed flow better though....)
#57
If you like them, fine, **** it, whatever. Your engine, your filthy oil, have fun. Just don't try and claim your anecdotal-based opinion is fact and negates anything to be argued against what you thing.
K&N threads - always more fun than watching atheists and Catholics go at it.
#58
Forums: where everyone has to have the last word. <3
I'm running a K&N on my car because it was on it when I got the car, but my next filter will be an Amsoil filter. If I found a K&N really cheap, I'd buy one. My experience does not include any negatives on them.
Playing devil's advocate here... Element, what studies can you provide to show dirty oil due 100% to the use of a K&N filter. Not saying they don't exist, but you are telling whigham about his "small test group". Let's see the opposite "small test group" that had dirty oil.
#59
someone wasnt held enough as a child.
my car came with the fipk k&n thing and i dont think i would ever go to a lid and paper filter mainly for the fact that i like the idea of a 360 intake like a cone or the wierd oval cone of the fipk much better than the flat lid style and i have personally seen the outcome of several street races changed by the removal of the paper filter and going "open airbox" i watched several very close races changed (granted they were with slow cars but that makes the comparison easier to watch) by somethin as simple as eliminating the paper filter.
me and a friend did a little rental car test one night. he had a honda and i had a mazda 3. it was such a close race it was retarded. but i popped the hood snatched the paper filter (which was not dirty what so ever it was a 2010 model car that lived in town and had 4k miles on it) tossed it in the back seat and we re raced. i ended up out front by a car. you do the math on what a full car length adds up to in the 1/4. another test we did was a 4x4 rcsb 05 chevy 5.3 truck vs a 08 titan 4x4 extended cab. the chevy would pull the titan pretty consistently. we stopped, removed the paper filter and the titan ended up wining by half a truck.
reguardless look at your intake setup with a level head and youll realize more air may mean more dirt or more blah but if your that worried about it maybe you would be better suited with a 4dr accord. i dont see top fuel dragsters worryin about their damn filters when theirs all manner of bugs and birds that could be sucked up at a moments notice.
and for what its worth my car has had the k&n fipk on it since ive owned it which is 3 years by now probably and its got 193k miles on the 100% stock bottom end and last i checked theres no mud in my oil. keep fightnin the good fight.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#60
I agree that K&N has had some great marketing throughout the years. People are still drinking that K&N kool-aid and putting those K&N stickers on their car as soon as those filters go in.
I wouldn't use one myself. I think they're over priced junk. They're advertised as a high performance air filter that adds horsepower. As soon as people read that, they can't resist.
I prefer a good brand paper filter like Wix. If someone wants to use a K&N, that's their decision.
