Cut out madness
#82
http://img89.imageshack.us/img89/2209/vwm.mp4
Can't figure out how to post vid so here is link. My daughter is running the camera. :10 mark is cut out opening up. Sounds deeper in person but you get the idea. She's a beast......
#84
You should Uploaded to youtube, and once you have. On the bottom of the video it will say share... Hit that, Copy the link and paste onto here. That way it has the lil window like in our previous post.
#88
Who has had electronic cutouts installed and failed... either by the heat of exhst or just plain rust?.... I believe i can adapt a motor to my Manual cut out thats in the Bird
#93
My cutout was open the whole time. They said the spike is probably because of wheel slipage on the dyno. There was a few cars there that day that had these random spikes.
#96
I have an older FLP electric cutout that is mounted on the over the axle pipe. Its got to be about 5 or 6 years old by now and did jam up once. I took it apart and sprayed brake cleaner on the gate to get rid of the carbon.
Having it on the other side of the axle doesn't give much of a performance benefit but it also means that the noise in the car isn't too bad. I run with it open most of the time. The cats are gutted and it does sound very nasty. When the car was H/C I still had cats and that eliminated the rasp. Don't have the raspy sound with this motor.
The FLP cutout it is a large heavy piece. It makes it hard to keep the exhaust hanging correctly because of the weight of it shaking it back and forth.
#97
#98
Here is a pic of where a single cutout on the i-pipe would go, and a video of an open y pipe (should sound *similar to a cutout on the i pipe)...
http://www.youtube.com/watch?v=08E6VFvwuOQ
^video doesn't do it justice whatsoever... much deeper at idle and has a lot of treble in the tone when you rev it up. Hope this helps,
-Marcus
-Marcus
#100
