Camshaft sprocket removal.
I've been trying to take off the camshaft sprocket but simply can't get it done. I have tried using 2 different pullers, but still no results.
Any tips and advice are highly appreciated.
The camshaft sprocket isn't pressed on. Just take the 3 bolts out and pull it off with your hands or tap it with a rubber mallet if it's stuck.
If you are talking about the crank sprocket and oil pump gear, you need to use a 3 jaw puller. Just make sure it is big enough to get to the very back of the sprocket.
what he said.
your camshaft sprocket has 3 bolts and a dowl pin that just keeps it on straight. after you take the bolts out it should just come right off. your CRANK sprocket is a different story and requires a puller. never tried removing one of those though.
You guys are correct. I did mean the crank sprocket, my bad. I have tried using different ones but it still won't budge. (even tho the pullers have a good grip on the gear.)
The crank sprocket just sits on the crank snout right?? Or is it connected to it? I just want to make sure that way I know how much MORE I should force it off, Thanks.
It has a light press fit. It must be pulled off with a puller. I have had good luck with 2 jaw pullers. I screw in an old stock crank bolt to give the puller something to push against.
