6.0 liter project need help
Old 12-11-2011, 10:27 PM
prostock555's Avatar
Default 6.0 liter project need help
hi everyone, i just got my hands on a 6.0 liter truck engine i will be putting this into a 87 grand national naturaly aspirated at first then twin turbo,down the road,i will be rebuilding this block with a stroker rotating assembly,,can anyone please tell me the proper and least exspensive way to control fuel and spark,,like should i use a truck harness or a f body harness and computer i dont want to use the drive by wire set up thanks a bunch....
Old 12-12-2011, 12:30 AM
Ironembraced's Avatar
I am not saying this is the way you should go, but it is one of your options.
Holley HP EFI system
Old 12-12-2011, 02:20 AM
bww3588's Avatar
Either operating system will work. Only benefit I can see using the f body computer and harness is they are more available for cable throttle bodies and are already activated to run your electric fans and the wires are already there for fans. You won't find a cable throttle body truck harness and computer with electric fans. They switched to e fans on the trucks in 05 and electric throttle in 03 I believe.
