Pulling 2 jet ski's with an Fbody
Lol at these comments, but for real if you wanna tow it to and from the dock, you can always drive them there and get yourself a 20' chain and wrap it around your trailer and hook it on to the hitch and lower the trailer down the ramp with a friend guiding it down, that way you have 20 feet between the water line and your car, and do the reverse to pull them out to level ground and hook em back on the hitch for driving. Better safe than sorry.
#33
![](http://i37.photobucket.com/albums/e61/ncsu602/SSatramp.jpg)
Saw this somewhere on here actually. I say go for it, two jet skis and trailer can't weigh much over 2000lbs. Just be aware if you're on a steep ramp or if you have to back very far into the water traction might be an issue, especially with older or z rated tires. We take our 21' Crownline (weighs around 5500lbs with trailer) with a z71 Sierra and have never spun once. However, I've seen a bunch of idiots at the ramps too.
I would try it on a quiet, less crowded evening with a friend there to help pull you back up if it slides. Just in case
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#34
i distinctly remember when i was a little kid back in 69' my cousin towing a speed boat with his 69' corvette. so why not? i'm thinking about getting a trailer hitch assembly just to tie the rear frame horns together. the oldman.......
#36
Yeah I am not so sure about this. I tow my snowmobile with my DD Subaru but total with the aluminum trailer that's only about 9xxlbs.
Having been around boats my entire life I don't think having to dunk the car in water and needing to get traction to go up a slippery launch ramp is really a good combo.
#39
Does trying to pull that amount of weight with a RWD sports car with summer tires on it up a slippery ramp still seems like a great idea?
#40
I think you are forgetting that he said 2. The double trailer weighs more, each jet ski is probably at least 600lbs if not more.
