'02 WS6 Fuel Tank Capacity?
I know the standard size for the fuel tank for this year is 16.8 gallons, which leads me to believe my fuel gauge is wrong. Is this a common problem with these cars? I know when I had my Firebird ('96) the fuel gauge wasn't very accurate, but I just want to make sure I'm not going crazy here. I usually fill up between 1/4 tank and E, and the most I've ever put in the car is 12 gallons. Are the odds better than my fuel gauge is off, or that the car has a smaller tank in it?
LS1Tech Administrator
Received 1,757 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Even when the gauge hits "E", most cars still have a few gallons left. This is normal. You could probably drive for another ~40 miles when you first hit E and not run out of fuel, depending on conditions and what sort of MPG you get.
Other than fuel cells for race cars, I don't think anyone even makes a smaller gas tank for 4th gens, so I'm sure your car has the stock tank. '93-'98 cars got a 15.5 gallon tank, but it's metal (yours should be black plastic, like all '99-'02 cars) so you can just look at it and see if it's correct for your year.
Thanks for the explanation RPM WS6. The one time when I filled it with 12.2 gallons, it was pretty much on E. I was expecting to put a lot more in, but that was all it took. I guess I'll just have to get used to filling at around 12 gallons, at least that is what I usually use in a week.
