Best way to clean intake runners and valves
So I found some oil in my intake manifold. I cleaned all that out but the intake runners where nasty and so where the valves. I was thinking maybe using seafoam but I heard that won't get all the cylinders so I was also thinking I could take the manifold back off and use brake clean to clean it up then change the oil shortly after. But if anyone has any other suggestions on the best way to clean it I'm all ears. Thanks
Internet Mechanic
Not sure if you mean the intake runner in the head or still in the intake manifold. Basically brake clean and a good clean rag would work to get misc containimates in the cyl head and soak up what does not evaporate.
Unless there is some nasty carbon or sludge I would not be going that over board. IF you so worried, pull the heads, have them disassembled, cleans and re assembled with new springs, I mean if your looking to get crazy.
To clean thoroughly you would have to remove the manifold and use a non-corrosive solvent to remove everything. The next best thing is seafoam or perhaps some carb and choke cleaner. However I'm not confident seafoam or the spray cleaner will make all that much of a difference. The only way to clean the intake runner of cylinder heads is to remove them and have them cleaned in a hot tank or sonic cleaner.
I've fixed the oil in the manifold problem and the carbon looks like its from oil burning in there I'm going to try some brake clean on there and yea taking the heads off would def be the best way but when I take the heads off I'll be replacing them with trick flow lol
What he said... I've done some before and after on a few engines and results were best with the above mentioned Mopar Combustion Chamber Cleaner.
