How to change running lights lens
I figured from the bottom,but I'm still a little shell shocked from a 20hr motor mount session with my car. So I'll remove the bottom splash guard go from there.
there is a drop down panel in front of the tire with 2 screws hold it up. Drop this down and you can reach in to the housing from the bottom. And no, you cant see anything, and its a long reach. It takes me several minutes to just change the bulb.
To change the bulbs is the easy part. I wanna change the entire housing and everything. Unless someone makes a replacement front clear lens.
