Wtf happened!?! Oil change gone wrong!
just got home. checked dipstick........dry. Though it probably has been draining all day though........(on my lawn, smooth move i know). I have the old oil filter in my hand and it doesnt have a gasket on it! you guys called it before i even got home, Thank you all
. Now i just hope i didnt bang any metal on metal with no lube......
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![Thinker](https://ls1tech.com/forums/images/smilies2/thinker.gif)
+ 10000 I saved a guy from ruining his engine because he was just sitting in his truck after he turned it on and immediately spued out oil because of the double gasket. He was lucky I was across the bay and happened to be looking in his direction lol
I knew it was double gasket mistake...seen it a few times.It actually happened a little while ago at my work when the "FNG" double gasketed a 42 quart capacity cummins DOHC ISX engine (15 Liter)...ever seen about 8-10 gallons of oil on the ground? Lets just say its an amazing mess. haha
#33
You should change your name to "Eagle Eye Buford". I'm just curious on how the hell you saw a oil leak across a bay?
#34
I haven't done that yet, but I have taken a oil filter and it was double gasketed the entire 3000 miles and it didn't leak, man the guy that did it got so lucky. I also have a friend who did that and blew up a motor, he was buying a motor for the customer and installing it for free lol.
#35
Yup, it was a $33 mistake. Could have been a $2000+ mistake. Hope alot of people are reminded of making sure the old gasket comes off. And i always lube up the gasket and threads on the new when i put it on, so i can stick even if you lube it up first. And i went about 3 months and 3k miles between the changes.
#38
Lol don't feel too bad man. The first oil change i did on my 79 Trans Am ended in disastrous results all over my friends freshly paved drive way. What happened was my car had the 6.6 Oldsmobile 403, and the guy at the Autozone gave me the filter for the 6.6 Pontiac 400, and that did not work out well at all, so now i always double check the filter. Good luck and hopefully all is well.
