Wtf happened!?! Oil change gone wrong!
#41
we all screw up once in a while...ive forgot to re install the drain plug after a cam swap....just cleaned the shop and while putting in the last quart of oil in i checked the dipstick and once i seen nothing it dawned on me. i just started laughing at my self...5 and a half quarts of royal purple on the ground of a fresh cleand shop floor will make for a good lesson learner haha.
#44
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
And because the bay I work at is only maybe 100 ft long and the front of his truck was jacked up facing me with the sun in back of the truck making a silhouette of a thick oil stream coming out from the bottom
#45
I had a motorcraft filter pop off after starting a fresh sbf 347 in my fox. shut car down quick and cleaned up. I checked the filter and seems that they didnt cut the threading deep enough on the filter. Could have been an expensive fix b/c of a $3 crap filter.
#46
I've just done the same thing. Got everything cleaned up and got new oil in. Seems to drive OK but I'm hearing a weird noise now. (It's a manual transmission).
Whenever i hit the gas I hear a noise and it gets faster the higher I let the RPMs go. If I drop it into neutral it goes away. I imagine some oil shot out into somewhere it shouldn't be, maybe it'll eventually burn off....
Any ideas????
Any ideas????
