Truck injectors in LS1 intake?
I am swapping my first EFI setup into a third gen, have the truck harness ready nearly, will be getting a LS1 intake, and i find them with no injectors, perfect since the truck harness will plug into the truck injectors i already have right?
Or will the truck injectors not be a direct swap?
LS1Tech Premium Sponsor
Like they said, some of the trucks got that bastard connector and you just have to get adapters or hardwire new pigtails in.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Actually it sounds like it will be that easy, you said you were using a truck harness. Nobody said anything about then not fitting the manifold just that they wont plug into a cars wiring harness, and you have a truck harness anyway.
