Know my mods, unsure on order
#41
i would just do a stall and cooler, drive it until you can afford (or are ready) to do cam/springs and tune. then when you are ready spray it. why spend a bunch of money replacing a GOOD rear or working transmission? either may break the first time you drive it or could last for years. if you were to replace everything based on the "it could break" factor you might as well do arp rod bolts and head studs, while youre that far why not just rebuild the motor with forged internals to handle the spray, and if you're going forged why not go stroker? this is how things get out of hand. you have a VERY low mileage car/parts so i would not replace the rear or build the transmission until you NEED to based on failure.
#43
My car still has the stock 2.73 geared 10-bolt, and the stock tranny. Just turned to 70,000 miles, and, by my sig, you can see it's making a bit over stock power levels. I didn't figure to have any trouble with the 10-bolt, since the car is an A4, but I've been waiting for the last 20,000 miles for the transmission to give up, so I can upgrade. It just won't cooperate. Of course, if I wanted it to hold up, it would fail.
#44
Did you get a new flexplate with your converter or stick with the stock one? I have a 99 so I think my stock one is a little stronger and since it only has 26k miles I don't know if it's worth spending the money on an aftermarket one.
