worth it to add ud pulley
I would agree with this, seems silly, when a lil overdrive thats easy to put on fixes it right.
If you want the car faster then I would do it, but I wouldn't do it just for dyno numbers. A dyno is an arbitrary tool, every one reads differently and can even vary by temp or location. If you try a different dyno you might be over 400 or way under.
If your not running an amp with subwoofers there is really no need for an overdrive on the alternator IMO.
If you want to consider trying to do it yourself there is a tool for putting the crank pulley back on with out risk of stripping the bolt.
http://www.coloradospeed.com/index.p...ducts_id=10976
It actually wouldn't be hard to back one with just some threaded rod and a nice size washer and bolt even.
It will add a few hp. Will you notice it? No. Its not possible to feel a 5-10 hp gain on an engine that is putting down 400 to the wheels Dyno numbers dont mean anything. If you really want to hit 400 try another dyno I guess.
#32
Take 4.10 gears for example, you'll lose power on the dyno but the car will feel much faster.
I know that's not the same concept but just trying to illustrate that rwhp numbers aren't everything.
#33
IMO, if you plan on spinning your motor past 6300rpm on a regular basis with the stock alternator then a 25% UD crank pulley is a good idea since it'll keep the the Alt. under 18k even if you spin your motor up to 7k. Or you can install a 3" UD alt pulley to keep the alt. under 18k. If you spin your motor up to 7k with the stock crank pulley and alt/alt pulley you'll already at 18k by 6300 engine rpm, and at 7k your stock alt is spinning at 24500rpm which isn't a good thing for a alt that should never see 18k.
BTW, I figured this with a 98-02 F-body LS1 7.5" crank pulley and stock alt with stock 2.625" alt pulley.
#35
#36
If you spin over 6300rpm(engine) then I would use the 25% UD crank pulley or a UD alternator pulley, not both. I don't know where you'd get a 3" alternator pulley but it would slow down the alternator the same amount. Either way I'd also bump up the idle speed to maintain the alternators stock rpm at idle to prevent any future battery charge issues.
#40
No, your engine idle rpms don't drop, but the speed of all the accessories do, so that's why you'd want to bump up the engine idle speed so the alternator will maintain it's minimum idle rpms and still work correctly.
