How high to jack car for head/cam swap..
Already got basic bolt-ons and cam in car but I didn't do any of the work. I finally saved enough money to get heads and I think I'm going to swap my cam during the process.
Question is I remember when a buddy put the headers on my car, the front bumper was nearly chest high.. Is it really necessary to go this high with the car?? They are Pacesetter LT's and considering its one of the first things I'll have to do in the process, I was wanting to see what other people have done..
for a header install at home, yes the rule of thumb is get the car as high as possible. for me i have access to a lift so i just did mine that way. for heads i see no reason why youd need to lift the car, other than removing the LT if you cant get em from the top now assuming you did AIR delete but good luck just doing my intake swap was a bitch.
I'm sure it depends on what headers you have but when I changed lifters in my old car with hooker headers I didn't do anything but unbolt them from the heads. The heads slid out easily. So I just had it high enough to get a jack stand under the car which is maybe an extra 8" or so
But like what others said just unbolt the y-pipe and let the headers drop down some. Good luck.
Depending how tall you are some people do better with the car having a slight elevation or just what the height that you get on the lowest setting of the jack stand.
Everyone have different approaches some cars you dont even need to remove the headers to get at the heads, some you need them out of the way.
