Idle adj problem or something else?
My car idles at 450-500 and I think it may be affecting my alternator. It the heat of the day I'm running 12-13v
It's the top one the bottom one is the tps sensor. It's just two screws.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If there is really something wrong the car will throw a code. The stock tach and voltmeters are only basic reference points and are not intended for diagnostics. There is paralax error while reading the gauges, which are inaccurate to begin with. If really concerned about battery voltage check it with a VOM (running and after sitting overnight). Read the idle with a scanner before adjusting with tuning software.
