Lifter tick
I fixed every exhaust leak
Spark plugs are tight
I have the valve cover off and I need help. The rods look straight, the bearings for the rockers are intact, they are clean, etc.
What do I torque the rocker bolts down to? I can try tightening them. Also if I start the engine with the valve cover off will oil spray out completely or just run out on the rockers/springs etc. I really want to pinpoint and fix this noise.
Can you start the car with the valve cover off? Will oil go every where?
I got a write up on removal and instal of the rockers and rods. I was going to start it up with the cover off and listen to which one is making noise then just a take that one off to fix it. If I only remove one rocker and rod can I just put it back in, torque it down, crank it over, then retorque it. Or do I have to go through the whole process of putting the engine at TDC and torquing them all in sequence?
As far as the rocker, I don't know if you can do just one but if it were me personally I would just go through the full sequence to make sure it's all right...
I started it and could clearly hear it in the car but I put my stethoscope on the bold of each rocker bolt and they all sounded the same. I couldn't pinpoint the sound at all.
I looked under the car and could hear it louder under the car but it could just be radiating through the long tubes.
What should I do next?
