installing heads and cam: how much hp??
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
hiiii
after i bought heads and cam for my 1999 camaro m6, i need your ideas,advices and thought before i start.
first
1/3/4 headrs
catback borla
slp lid
85mm maf
intake,throttle fast 92
205 AFR heads with 64cc
MTI CAM S1 244/244/ 612:612,112
7.4 push rods
660 valve springs
with 3.73ratio basically, after mothe i will install 4.10, ok??
i want to put 27 or 40 cometic heads gasket.
my stock shortblock with 85000 miles.
what your thought about this project and what should i do?
how much i will gain horsepower
your frinds from bahrain,
first
1/3/4 headrs
catback borla
slp lid
85mm maf
7.4 push rods
660 valve springs
Are you planning to notch your pistons for valve clearance?
That's a lot of cam duration for your compression ratio.
I wouldn't run less than .035" quench, which will require at least a .042" thick gasket. Too tight of quench can allow the piston to hit the head and damage the top ring land.
If you want more compression I would mill the heads. Milling them to 61cc will give you around 11:1 compression.
I prefer cams in the 231-235 intake duration range and about 8 degree split from intake to exhaust. This type of cam will have the piston to valve clearance that you need and will make great average power and very good peak power also.
I hope this helps!
I don't see any way that your cam will clear stock pistons without notching them.
You should be able to make over 440rwhp with a smaller cam like I described and have your valves clear your pistons.
