rear end swap
just swap the carrier and gear set, wand make sure the reluctor ring will work with the LS if not pop off the ring gear, swap the reluctor, and put the gear back on. I wouldnt swap the whole housing.
I was able to make it work. I swapped the axles and brake backing plates from the LS rear into the housing of the LT rear. I had to grind the axle tube backing plate flanges on the LTs housing to accept the LSs backing plates where the speed sensors are but other than that super simple. Got my 4.10s back!!!
