The 13111 corvette o2 sensors will be plenty long enough for the long tubes. Remove the stock ypipe before the trasmission removel, once tranny is back in put the headers on. I swapped out my headers twice and used the stock oem gaskets and bolts both times, still no leaks however on the second time couple bolts backout due too viberation. So be sure to check them, use OEM GASKETS! On the passenger side remove the coil pack and bracket for easier bolt access.(it may be easier too remove spark plugs on the driver side for easier removel) Soak the stock exhaust manifold bolts and y pipe bolts with "pb blaster" most of the bolts will break when removing them, pb blaster will make it alot easier for removel. Motor mounts wouldnt be a bad idea, but at the very least change out your transmission mount bushing. My camaro had 45k miles on it when I did header install and that bushing was bad. Get you a nice set of ngk plugs while the headers are out. You can install the passenger side plugs before you install the passenger side header, however on the driver side, get the driver side header on before you install the plugs. The driverside header is alittle tricky too get past the k member so be patient you can get it slid in. There are two bolts and a plate on the driverside on the oil pan(not sure what it is, I think its for a after market sensor or gauge) remove them two bolts and plate and the driver side header should slide past the k member. Your gunna need someone too hold the headers from the bottom while you get them bolted on(common sense be patient and careful not too cross thread your header bolts) get all header bolts snug before you start torquing them down. DELETE THE EGR!!! ITS GARBAGE. Either buy headers with no egr valves or buy the block off plates. I highly suggest if you dont plan on removing your tranny anytime soon WELD! Your YPipe! keep your band clamps but weld everything else. With your ypipe your going to bottom out on every speed bump and it will eventually cause bad exhaust leaks and you will be stuck welding it anyways. I got frustrated with the garbage ypipe and got custom true duels made, well worth the money and low end torgue over a ypipe!!!! With tranny removel make sure you have plenty of extenstions! and a tranny jack it will make life way easier
Any other questions feel free to ask, if I think of anything else ill let u know. Good luck! Its not as overwheling or painful as it seems!
