Hood hitting air lid
Old 04-24-2013, 08:12 PM
juicestain's Avatar
Default Hood hitting air lid
I have a 2000 SS. Is there any way to stop my hood from rubbing against my air lid? It looks nasty when i pop the hood and is causing damage to the paint. If not, then Is there a particular brand that fits without rubbing? I'm not sure what brand I have it was on the car when I got it. I recently upgraded to the FAST 92 intake and was debating on getting the FTP 98mm, has anyone had rubbing issues with it?
Old 04-24-2013, 08:20 PM
HCI2000SS's Avatar
Is it a SLP lid?
Old 04-24-2013, 08:23 PM
senicalj4579's Avatar
My lid does it too and I dont worry about it. What are you going to do? I dont think there is anything really. BTW mine is a FTP 98mm lid lol
Old 04-24-2013, 08:43 PM
AmDWs6's Avatar
slp 90mm and it slightly hits the hood... don't care. lol
Old 04-24-2013, 08:50 PM
PhoneniX's Avatar
my slp lid rubbed into the fiberglass before i got the car. it also has a smooth bellow and after trimming the bellow a bit and being sure to align the notches i no longer rub . however the pos only latches on one side still
Old 04-24-2013, 08:58 PM
Cajun ELESS-ONE's Avatar
iv got a slp and a trufiber hood. it rubs also. i adjusted the rubber stops and added washers to the bolts on the latch and it still rubs alittle. maybe another washer will do it
Old 04-24-2013, 09:04 PM
BigMac76's Avatar
Older slp lids are known for this actually. Mine no longer rubs. I took a heat gun to it and gently heated it up and massaged it down until it didn't rub against the ss hood. If you do heat it up, use a wide circular motion and bring it down uniformly.
Old 04-25-2013, 10:07 PM
PhoneniX's Avatar
Thumbs up
thats a damn simple idea, im surprised i didnt consider this. It does sound risky if ya get a little too generous
Old 04-25-2013, 10:39 PM
kingof951's Avatar
i have an slp on my 00 ss and used to rub but smooth bellows and a little moving around and adjusting did the trick.
Old 04-26-2013, 04:57 AM
roninsonic's Avatar
my SLP lid rubbed, as well. Pretty common.
I just switched to a sheetmetal 110mm lid
Old 06-29-2013, 10:40 AM
PhoneniX's Avatar
oddly enough the dyno tuner i went to did a quick repositioning and he figured it out. i stopped the rubbing but it kept popping out of the one clasp, he got it to stay its been a week too. i guess practice makes perfect
Quick Reply: Hood hitting air lid
