ATTEN: M1 full sythetic VS Castrol gtx sythetic
Originally Posted by TX_SS
which one is better motor oil??? ive been using 5w-30 M1 in mine..but heard castrol is better..
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by VIP1
Mobil One is a real synthetic, Castrol inst.
I think Patman had a post on here a while back about it. Do a search and you might find it.
--VIP1
--VIP1
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
The Castrol Syntec 0w30 from Germany is the good one, it's much better than Mobil 1 5w30, but the Syntec 5w30 and 10w30 are completely different from the German stuff and is not as good. They are both thin 30wt oils. The 0w30 Syntec is very close to being a 0w40. And yes, I've seen amazing oil analysis results on every car I've run it in so far, and other people's oil analysis results with this oil have also looked very good, it's yet to post a bad report.
So far it's only available in Autozone in the US, or Walmart in Canada (and some Canadian Tire stores)
Look for the made in Germany label on the back, not the older US made 0w30 Syntec.
Yes, this 0w30 is totally safe to run in the hottest weather, since it's almost a 0w40, so it will be thicker at operating temperature than something like Mobil 1 10w30 for instance, which is on the thin end and is almost a 20wt oil.
Redline is definitely very good, and definitely one of the best. The only problem is that Redline also costs a lot more than the German Castrol. Up here, Redline is $12.99 per quart, versus $6.66 per liter for the Castrol. So being double the price makes it hard to justify for a lot of people.
TX_SS, I'd recommend going with the K&N oil filter, as the M1 oil filter is very restrictive to flow.
patman, is there anything else that i can use besides K&N oil filter....bosch?? fram?
Assassin, I've never seen GTX 20w50 in an LS1 but I've seen an analysis on GTX 10w40 and it looked very good (although it was a short 2500 mile interval) If I were to ever run a conventional oil it would most likely be GTX 10w40. (although I still prefer synthetics)
i started using the 0w30 syntec about 500 miles ago. so far i've not used a drop of oil; before, with 5w30 M1, i used about a quart over the course of 1000 miles, which was about half a quart per 500 miles. so far, the syntec has proven itself worthy to me. i'm sure i'll burn some oil, but it's not looking like it's going to compare with what M1 burned!
![Suspicious](https://ls1tech.com/forums/images/smilies2/suspicious.gif)
