Stealth plate...
and that **** gets documented, thats just one of the reasons why I dont want every ******* w/ a cell phone to get my plate number....... I tried searching google but didnt come up w/ anything, if you dont know what I'm talkin about it looks like a clear licence plate cover when there is power to it, but when power is cut off (via a toggle), it goes to lcd gray and you cant see through it
Mike
Sweet!I'd like one also! Mike
It was glass, and would fog up completely with the flick of a switch in about a half a second.
I'd like to get one
so does it need CONSTANT power for it to be clear?
or would you be able to wire up a switch
IE: so you don't run you battery dead so you don't get a ticket when you park your car
"privacy glass laminates 3M Privacy Film between two panes of glass. The windows are wired to a wall switch that uses the same voltage (120V/240V) as standard household appliances. With the flip of a switch you can instantly change the glass from clear to frosted. It's that simple."
technical info
http://www.glassresource.com/sub/special/privacy.htm
aka Liquid Crystal Privacy Laminate
http://www.laminatedtechnologies.co...vacy_films.html
Main problem i see---->
"Electrical: Consumes less than 1 watt per foot. Minimum voltage requirement is 80 volts AC. Switches from frosted to clear in 25 milliseconds or less."
3m is experimenting with uses for this technology and has encouraged engineers to contact them with ideas. who here is an engineer and wants to make a suggestion?
i'm gonna call around this coming week and see if anybody can sell a liscense plate sized section of this glass with 4 holes bc this would be a badass/unique mod.
