Spend my money! "Best" way to get to 400-450 HP? '01 WS6 A4.
#61
ok to the OP
ill just throw my 2cents out there from my own experience my car is an 02' WS6 A4,yank 4200 stall, flp long tube headers,true duals with dynomax bullets,TSP lid and a RPM cam with the best tune from one of the best tuners(no BS lol) in the USA and it dynoed 414rwhp 390rwtq this is with a stock block,heads,intake,gears,mass air meter,everything stock including weight i think the TUNE and TUNER is the most crucial part of it all and i didnt spend nowhere near 4K my car went 11.78@116 on a 100* day in texas my tuner said in the cooler weather the car would go mid 11's and with a 100 shot of the sauce it would run high 10's and would put down 500+rwhp on the sauce which i never did but i drive this car everyday and have for 4 years just the way it is just another opinion for you good luck to whatever you do!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#63
ok to the OP
ill just throw my 2cents out there from my own experience my car is an 02' WS6 A4,yank 4200 stall, flp long tube headers,true duals with dynomax bullets,TSP lid and a RPM cam with the best tune from one of the best tuners(no BS lol) in the USA and it dynoed 414rwhp 390rwtq this is with a stock block,heads,intake,gears,mass air meter,everything stock including weight i think the TUNE and TUNER is the most crucial part of it all and i didnt spend nowhere near 4K my car went 11.78@116 on a 100* day in texas my tuner said in the cooler weather the car would go mid 11's and with a 100 shot of the sauce it would run high 10's and would put down 500+rwhp on the sauce which i never did but i drive this car everyday and have for 4 years just the way it is just another opinion for you good luck to whatever you do!![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#70
Speed Inc LS1 custom grind 231 237 .589 .595 112
Speed Inc 5/16” diameter, 7.400” Long Chrome Moly pushrods
BTR .660 lift extreme dual spring kit with Chrome moly retainers
Melling LS1/2/6 performance oil pump
Gen III LS1 & LS6 Single Row Chain (Torrington bearing fitted)
Camshaft installation gaskets
GM Water pump gaskets (2)
GM Balancer bolt LS1/2/6
GM crank seal
GM oil pump O ring
Coolant, for cam/heads installation
Fluids H/C Synthetic oil and filter change
A/C RECHARGE
Yank Super Stock 245mm 3600 stall 2.5 STR
B&M 24000 GVW Trans Cooler
Transmission R/R
TSP 1 7/8" LS1 F-body Headers
TSP 3" Y-Pipe for TSP, Hooker, Pacesetter Headers - Off Road
GM Steel Header Gaskets (pair)
NGK Copper Spark plugs set of 8
MSD LS1 Superconductor 8.5mm Wires
Speed Inc 24" O2 sensor extension, Square 2
Dyno tune 98-Current LSX
GM crank seal
GM oil pump O ring
A/C RECHARGE
Transmission R/R
#71
^^^ Good stuff right there. Looking forward to seeing what she ends up putting down. Did they give you any idea what to expect?
Also, do you plan on going down to Bowling Green this year for Holley LS Fest? I think I may be going. If you do go, we could meet up somewhere in Illinois and drive up together.
#78
I think you'll hit 400rwhp. The, if you add heads and intake, depending on the combo you go with, that should add another 60 or so HP. Have you thought much about TFS 220cc As Cast heads? You can get them through Brian Tooley for a really good price, and if you have an extra $300.00, he will hand port them for you, putting them on par or above the TFS 215cc CNC'd heads.
#80
