Check engine Light
It should turn on with the rest of the gauge cluster lights when you cycle the key to the on position (engine off), but it should shut off right when the key is moved to the "start" position, along with the other lights. At that point it should not come back on while the engine is running unless there is a fault that commands the MIL.
