Service engine soon
Old Oct 12, 2014 | 12:41 AM
1LE Hugger Orange's Avatar
Default Service engine soon
What does that message mean ?
Old Oct 12, 2014 | 12:48 AM
Mercier's Avatar
That usually means you have a code in the computer that needs to be read and interpreted. Should point you to a problem or a sensor reading out of spec which might point to a problem. Some vehicles will do this at certain maintenance intervals(mileage) to encourage you to perform certain maintenance tasks. AutoZone will read them for you for free if you don't have a scanner.
Old Oct 12, 2014 | 03:47 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Service Engine Soon (SES) is the specific term used for LS1 F-bodies (as well as some other vehicles) to represent a MIL (Malfunction Indicator Lamp). This type of MIL can only be illuminated for an emissions related fault/fault that creates an increase in emissions levels (Type A or B DTC) and not to indicate any sort of mileage-based standard maintenance intervals.
These cars also have a "Service Vehicle" light (as well as a "change oil" light on later model years) that doesn't directly indicate an emissions related fault.
Old Oct 12, 2014 | 07:50 AM
ULTIMATEORANGESS's Avatar
if its blinking that means something serious.
at least in my case it was.
Old Oct 12, 2014 | 09:59 AM
Jay-P's Avatar
If you need the codes read let me know, we can meet up, or you can come over. PM if you like.
Old Oct 12, 2014 | 01:54 PM
RPM WS6's Avatar
If it's blinking then the PCM has detected a serious misfire. You will then likely have a P0300 DTC as well as a cylinder specific DTC (P030x; x = 1, 2, 3, 4, 5, 6, 7, 8)
Old Oct 13, 2014 | 07:32 PM
Mercier's Avatar
While we're on the subject..what event or events does the PCM use to determine a misfire? "Serious misfire?"
