o2 simulators
You never want to use a simulator in the front (pre-cat) locations, as they are not actually a sensor. You need a correct and functioning O2 sensor in each pre-cat bank.
The pre-cat o2 sensors are there to tell the PCM how much fuel is being put into the cylinders vs how much air by reading how much oxygen is in the exhaust. If it sees a lot of oxygen it reads low voltage, if it sees a little, the voltage is higher. This tells the computer to add more or less fuel.
A normally functioning PCM with normally functioning o2 sensors will constantly flip between rich and lean, as the computer is constantly adjusting.
The post-cat o2s are simply there to monitor how efficiently the catalytic converter is working. If it's not there/not working, the PCM illuminates the SES light and gives you a DTC. It is okay to simulate the rears because they do not affect how the car runs.
