5.3 heads
Yes they will bolt on. Just did that to my truck that had a cracked 706 head. They need to be milled some as the chambers are 64-65 cc vs the 706 heads with 61cc. Had mine milled 0.030" to get the chambers to 59-60cc and used the stock ls1 mls head gasket that compresses to 0.051 to give me about 9.9:1 compression.
Also when doing this you need to check your pushrod leangth as you are changing the valvetrain geometry around.
