LS1 Removal
I have a 2000 trans am. I am about the remove the engine and have the bottom end rebuilt. I do not have access to a lift, so my question is has anyone pulled on of these from the top? if so what all has to be done.
Any information is greatly appreciated
I pulled my LS1 from the top , 1999 Z28 , the car went up on blocks under the wheels with built in stops to prevent the car from rolling off . Can not be done with the trans on the engine . Pulled the trans , bellhousing ,clutch and flywheel. You have to remove the intake manifold for clearence and unless you pull the front bumper assembly , you will need a cherry picker with at leat 50"
of reach . The rad , fans , have to come out . Slow process , 2 guys , one on the cherry picker and one guiding the engine out.
