98 Trans am Stroked
well then do you think I should start over with the upper engine mods and buy a kit to tie it all together ??
we have not mad any changes except clutch since 2008
and have not run the track since then also we are in Idaho now so would have to run in Boise which the air is going to be completely different
If I were going to buy a motor already put together, I'd call these guys. If you're going to build it yourself, I'd call Thompson Motorsports or Texas Speed, both are sponsors and they can help you with what you need. If you're going all out on your heads, then I'd probably have Advanced inductions work them over or Tony Mamo do them, he's a sponsor here as well.
Good luck on your build man, it's well worth it when it's done
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
yea I will call them however the lower end is fine I just need the upper end parts redone. the stroke and all that doesn't have that many miles on it. its all the mods and so on that need tightened up
I will talk to both those places and see what we can come up with
thanks
thanks
lol... Yup time to start over man sorry. There are bone stock cars putting down better numbers than that. A full exhaust LS1 T56 car should be putting down around 350rwhp, so seeing that you have boltons and a cam something is very wrong.
Well with everyones thoughts I am taking it to a local shop to make sure all the basics are ok. After everyones htoughts I am wondering if maybe when the shop tuned it they did something wrong?? We bought the software and he tuned it all so I am wondering if the ECU is all out of wak
Ok its in the shop he is going to check the computer see if he can find whats wrong we also discussed that we do not know if it has a good fuel pump to keep up with fuel demand
#32
