Fuel pump
Old Mar 20, 2016 | 12:57 PM
Ryankonopka's Avatar
Default Fuel pump
Hi guys, Lost fuel presure on my 1999 Trans am with the key on its at 20psi, at idle drops to about 15. Is it the regulator filter or what? the car will start but to keep it running i have to feather the gas
Old Mar 20, 2016 | 01:54 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Nothing wrong with changing the filter first, just in case it's blocked and that solves the problem. But I would plan on having to replace the pump as well. The regulator is part of the pump assembly, it's all in the tank.
Old Mar 20, 2016 | 08:32 PM
I thought the regulator was in the middle of the fuel rail?
Old Mar 20, 2016 | 09:10 PM
usnfenix's Avatar
this is a common misconception
your actual fuel pressure regulator is in the tank on top of the fuel pump itself.
Old Mar 20, 2016 | 09:11 PM
usnfenix's Avatar
read this thread, will educate you and might fix your issue
https://ls1tech.com/forums/fueling-i...ssue-read.html
Old Mar 21, 2016 | 08:01 AM
SouthernRex's Avatar
The regulator was on the rail for the LT1, but as stated, not the LS1.
Old Mar 21, 2016 | 09:59 AM
ok thanks guys, How hard is it to drop the tank? is there any step by step instructions on here?
Old Mar 21, 2016 | 10:06 AM
murphinator's Avatar
there is an alternative to dropping the tank , search trap door mod.
Basically it involves cutting out the metal above the tank then adding an access plate to cover the hole like what w bodies have. I wouldn't do it on a collectible low miles high value car but my m6 car in my sig already has it done and any of my others would get the same , once its done fuel pump access is easy.
Old Mar 21, 2016 | 01:46 PM
RPM WS6's Avatar
Honestly, even in this case I would and will if I ever have to. It's not something that would ever be visible, nor is it harmful to chassis integrity. Some cars have these access panels from the factory as you mentioned. IMO, doing this mod is just correcting a factory oversight (sort of like drilling access holes to remove the rivets for power window motor replacement.) The factory put cut provisions in the rear carpet for access to the shocks, and they should have done something for the pump as well.
Old Mar 21, 2016 | 02:56 PM
The car is almost in mint condition no rust anywhere I dont wanna put holes in it....I would apresciate it if you can lead me to any type of form to drop it. Also I saw a msd fuel pump and reg for $160.00 are there any brands you guys recommend?
Old Mar 22, 2016 | 09:06 AM
I found a really good video on just to cut into it. So I guess im just going to go this way where is the regulator is it on the pump?
Old Mar 22, 2016 | 01:15 PM
RPM WS6's Avatar
Mine is a 17k mile 97-point show quality car, but I would/will still do the access panel as it should have been done from the factory and won't be visible once complete.
The regulator is part of the assembly/module, and it's included if you buy a new complete assembly/module. If you buy a "pump only" you won't get this part, and you'd have to reuse the rest of the factory module.
Old Mar 22, 2016 | 10:02 PM
BlackedOut LS1's Avatar
Dont drop the tank, just cut the top, do a search there a google video. I done it and it saved me big time, bc now I have to change the sending unit also. If you get a fuel pump just get the racetronix with the hotwire kit also.
Old Mar 23, 2016 | 08:01 PM
usnfenix's Avatar
your more than welcome to drop the tank. However I will bet $100 you will hate your life about halfway through, probably right about the time your halfway done with dropping the rear axle.
do the trap door, seriously youll forget its there and its no big deal at all.
your call though.
Old Mar 24, 2016 | 09:14 AM
Cut it out last night, figured i would drop a pic for anyone trying to do this on there 99+ TA. Still waiting for my racetronix 255l/hr to come, Just woundering sinse this pump has a little more juice than the stock, would upgrading my fuel rails show a noticable difference?
Old Mar 24, 2016 | 09:58 AM
your stock fuel rails will not be a restriction on any setup with a 255 pump
Old Mar 25, 2016 | 03:03 PM
I cant get the washer holding the pump in to twist out any advice?
Old Mar 26, 2016 | 05:46 AM
NineZeroFive's Avatar
Do a search with my name and check out my write up. Details easy way to do it.
