loud "creaking" noise over bumps...
I recently put these parts on my car all in the same day:
SLP weld in SFCs, 21mm rear and 35 mm hollow front bar, and a cutout.
The front bar was put on using the stock bolts, endlinks etc. (not the ones it came with, guy said the bolts the new bar came with weren't long enough).
I notice now I have this loud creaking noise whenever I go over bumps.
I also have had a really loud banging sound about 4 times now. At first I thought I was just going over one of those metal plates in the road and it made that noise but since that it has happened a few other times. It sounded like it came from the back of my car. I guess it could be a backfire but I've never had those before so I doubt it's that. It sounds literally sounded like someone slammed a heavy metal plate on the road.
Anyway, what the hell is this creaking noise??? I need to get rid of it asap.
Do I need to put some wd40 on the bars or what???? Do I have some other problem? help me out!
I don't think the cutout is hitting anything. It only hangs about half an inch (if that) below anything else under my car.
Each time I heard that loud bang it happened while my back tires were going over a bump or rough spot in the road. Most of the roads in LA are pretty shitty anyway so that might not mean much. I didn't go over anything high enough to hit the bottom of my car and make that kind of noise though.
The first time it happened was when I drove over a metal plate in the road so I thought maybe it was that but then it happened 3 other times so far (over a couple of months) and I don't recall going over a metal plate each time. It's not something I've been able to reproduce just by going over some rough road or bumps so it's hard to tell what's going on.
Now this other creaking noise is easily reproduced. Every time I go over a bump I hear that from under my car. I'll try greasing the bushings and hope that works. I'm not sure when I'll have time to do that though... I hate it when I do **** to my car and I have problems after
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Now this other creaking noise is easily reproduced. Every time I go over a bump I hear that from under my car. I'll try greasing the bushings and hope that works. I'm not sure when I'll have time to do that though... I hate it when I do **** to my car and I have problems after![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
