LM7 stupid questions
Bought an LM7 to put into my 91 camaro also have an LS1 intake complete with LS1 fuel rails and injectors, to put on it due to hood clearance issues. Will I need to do a tune for this?
Also bought my engine without manifolds. What would be the best headers to put on?
you need a tune to remove the anti-theft from the pcm so it will run anyway... you don't necessarily need a tune just to swap manifolds, but it's always a good idea to make sure fueling is correct. make sure the injectors are the same flow rate as what you're swapping out... are you running the MAF too?
