Exhaust advice
LS1Tech Administrator
Received 1,793 Likes
It's not a simple answer since the driver's side pipe is oval - though the flange is not.
i have 2 ws6's
both are stock first one driver side pipe oval and magnaflow
and the second with Y pipe and magnaflow
with Y pipe more noticeable in idle and cruising i like it
You will also need a tune if you want to remove the cats or do LT headers to turn off the check engine light, some power will be gained from the tune as well.
