Push Rods
Old Sep 16, 2017 | 07:55 PM
1LE Hugger Orange's Avatar
Default Push Rods
Just got the car back from getting a WOT , pulled 418 RWHP , the tuner is wondering if my push rods are too short? Would that affect the lift of the cam ?
Lg Motorsport 600/610 and around 240 duration.
Old Sep 25, 2017 | 01:39 PM
biketopia's Avatar
Will 100% affect the lift on the cam. Did you measure your push rod length or just go with stock rods? What else was done to the engine?
Old Sep 28, 2017 | 10:59 PM
Stock length comp cams hardened push rods, has a LG Motorsport cam, .600 intake/ .610 exhaust and around 240 duration . It has double comp valve springs and trunions in the stock rockers as well as well as a double chain. New oil pump, 7 quart oil pan with a remote filter, Kooks long tube headers, y-pipe with high flow cats . 10% under drive damper , LS6 intake SLP air box and a K&N filter. Air pump delete but still has O2 sensors .2001 LS1 not a 1999 .
Old Sep 29, 2017 | 05:59 PM
KCS's Avatar
KCS
Moderator
Pushrods won't affect lift unless they are WAY too short, but then you'd probably be hearing some clattering noise from the valvetrain anyways.
Old Sep 30, 2017 | 10:06 AM
PhoneniX's Avatar
I had too short of pushrods when I first did my cam. It did clatter, when I went back to the same tuner with the correct length rods it didn't make any power change. So I second KCS opinion. Just more valve train noise and likely wear unless you really botched the length beyond the hydraulic lifters tolerance.
I have less lift in the cam grind but otherwise all the same upgrades as you listed. 224/228 .588/.581 @110+4 comp cam.
Old Oct 1, 2017 | 11:55 AM
pantera_efi's Avatar
Default Lifter Bleed Off
Hi Hugger, I ASK for the Noise Pressure AND RPM when this problem occurs ?
My experience has shown with High Spring Pressure, the Lifters will "bleed off" after 6200 RPM with Steel Valves.
Lance
Old Oct 8, 2017 | 06:33 PM
I notice it when I am warming the car up, especially with the hood open . Oil pressure seems good , close to 50 cold idle never below 40 when warm. Exhaust is too loud to hear the engine when driving.
