Hello I'm new. Need some input on a cam
Hello I'm building a gen iv 5.7l from a 5.3l. I been shopping around for cams. Right now I've settled on this one. Here are the specs any input would be great.
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,500-6,800
Intake Duration at 050 inch Lift:226
Exhaust Duration at 050 inch Lift:226
Duration at 050 inch Lift:226 int./226 exh.
Advertised Intake Duration:275
Advertised Exhaust Duration:275
Advertised Duration:275 int./275 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.598 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.598 in.
Valve Lift with Factory Rocker Arm Ratio:0.598 int./0.598 exh.
Lobe Separation (degrees):111
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:Yes
Valve Springs Required:Yes
Camshaft Manufacturers Description:5.7-6.0L engines with Cathedral port cylinder heads, greatly improved power band over stock, computer tuning required, slight choppy idle, best for stock motors with bolt on parts and tight torque converter.
Hi Yukon Matt, The cam specs look good, but for any good suggestions guys will need to know more info like
vehicle it will be in, what will be the vehicles purpose/use ie..daily driver, weekend only, towing, offroad etc.
It's going in an 07 Yukon 4x4 (not the xl). It's not really a DD because the company I work for provides me a truck that I drive home. It's used only for running around town and the occasional road trip. It might do some light towing every now and then. I have two other trucks to tow with nothing heavy. The truck has 3:73s and 4l60e which will be getting a corvette servo to start with until it Taks then a full work up. It still has to be streetable. My goals for the build is around 500hp.
Thank you for the input. I'm think I'm going still go with this one if I don't like it it won't be that hard to go to a smaller one since it'll already have all new lifters and springs etc.
