shift light help
Sounds to me like your Harlan has just taken a dump. Check into getting a Raptor if you can't get your Harlan replaced..
You right.. Check your tach connection..
is there anyway i can find out if the tach wire is sending any information to the shift light or not? if it is, then the tach wire is not at fault, and it's probably the shift light. if there is no signal, my wire is bad. i just did this about 2 weeks ago, so that would blow my mind if either of those are the case. damn luck.
The only wire left is the tach one. Make sure the connection is good, and there are no cuts along the wire. However, are you 100% positive you are using the right wire?
Last, make sure that you have the shift light setup for a 4 cylinder. If it's setup for an 8 cylinder, it will not work properly. LS1's tach output is a 4 cylinder instead of an 8
any other thoughts?
any other thoughts?
You should give it a try.
Kevin
Just thought I would put that out there..
