Which spark plugs should I use
"Stay away from platinum plugs - they heat up fast and stay hot causing pre-ignition." This months article about LS1 Do's and Don'ts in either Super Chevy or Camaro Performance - can't remember!
Originally Posted by 98gibzilla
How many miles will these NG's last? Also, what about the GM Performance wires?
Thanks
Thanks
I don't know too much about GM products. For performance, I don't use GM. Too pricey. You can get better parts cheaper from other places. I changed out my stock wires for Taylor 8mm.
hey patrons thatdont think wires make that much of a differance my buddy made me a set of D.E.I[earnhardt] nascar wires from packard electric what a differance. but what are best plugs for 98 Z28 6 sp.
i have access to a computer at work and i looked up what plugs i should use for my 99 z28 ls1 this is what i found.
INFORMATION ON NEW SPARK PLUGS AND GAPPING:
chevrolet camaro with 4.8L, 5.3L, 5.7L, OR 6.0L V-8 ENGINE (VINS V,P,T,Z,G,S,N,U -- RPOs LR4, LM4,LM7,L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. the new spark plug has an iridium tip instead of the current platinum tip. due to the different tip design, the gap of the spark plug has also changed. the new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. the spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. any new spark plug found to not be properly gapped should not be used
these are the plugs i used for my car, so far so good...
just thought you guys might want to know,,,
99bluethunderz28
99bluethunderz28
Originally Posted by Fred99Z28
In my opinion stock wires are crap (Packards @500 ohms per foot), my $65 MSD 8.5 super conductor wires are 40 ohms per foot & allow for alot more current to pass. More current means better spark which means more fuel taken care of (More power made). JMO-Fred
when i got my msd wires i read them with my fluke meter and they all read at
28 ohms, a heck of a lot better than the stock carbon strand 700 ohm wires.
and stick with the ngk tr55, or tr6 plugs, or if you have the money go with denso irrideum plugs.
hope that helps
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
hope that helps
hope that helps
AS for letting people getting recomendations from mechanics......STOP!! People do not understand this motor, it is unlike any small block chevy has ever produced, and requires certain things other motors don't. Another thing is magazines are dumb, and so is Horsepower TV. These people seem to go on here, and find what the LS1 know it alls say not to do, and do it. But that is a whole different story.
The NGK plugs are absolutly fantastic, and DENSOs are not as compatable with the LS1 motor for some reason. If these plugs are fireing in the fastest LS1s in the world, why can't they be in ours? They are proven time and time again thay can support power, and deliver spark strenght correctly and effeciently.
To the guy who said "Should i consider changing the wires as well? My mechanic friend said the wires look good" unless your friend has x ray vision i dont think u can look at wires and say they are good. Its standard when u do plugs, u do wires. I went with the NGK TR55 and MSD 8.5 wires plugs from thunderracing.com and wires from jegs.com
Also to the guy who says "The NGK plugs are absolutly fantastic, and DENSOs are not as compatable with the LS1 motor for some reason." FYI Denso is made by NGK, they are good plugs seems the douche bags in the factory dont gap them right/consistent half the time.
Originally Posted by LT1 Guy
Get the irdium plugs if you can. Irdium conducts electricity better than copper. Plus, it'll live longer.
