O2 sensor
http://wbo2.com/sw/logtech.htm
"All Tech Edge's Wideband (WBo2) units include some form of serial (either RS232, USB, or CAN) logging capability. Some include on-board logging memory for data collection without a PC (3A2/3E2, 3B1), and others don't (3A1/3E1, 2C0, 2D0/1, 2J1, etc.) but they all generate a serial data stream that can be sent to a collection device (a PC, etc.) for later analysis."
P.S. Throw in a new torque arm mount bushing and a trans cooler while you are at it.
Tuners (like me) use WideBands for logging and adjusting the tune according to your setup. They are the most used sensor in any tuning software. It is critical that you know the actual air fuel ratios rather than relying on a traditional Narrowband O2, which is only accurate at or near Stoich values (14.63:1 AFR).
Traditional O2's also only produce up to about 1.2 volts (typically 1), depending on the difference inside and outside the pipe. The more fuel = less air, the more voltage it will produce. Typically around 900-975 mV when very rich. So that is the range the PCM expects to see, 0 - 1000 mV (1200 according to the range in the tune). A WB signal would not work on this input since most of them typically produce up to 5 volts.
ss.slp's post above is correct as you can analyze the data later, or in real time. The PCM though, cannot use these inputs to make adjustments. It would be pretty cool if it could though, but it just wasn't designed with that in mind.
Tuners use WB to tune the MAF and VE tables. These are the two most important fuel tables in your tune. These can have a drastic effect on whether your engine blows itself up during a super lean condition, or lives to race another day.
