Stupid ?
my question is why does this forum call it the gen 3 if the Camaro is the 4th gen? Im looking to buy a lift plate to remove the block but there asking if it's a 3rd or 4th gen now i know the car is a 4th gen is there a reason the forum says its a 3rd gen? Which plate should i get then the 3rd or 4th gen plate?
92-97 LT1 engine = Gen II
97-04ish LS1/6 + truck variants = Gen III
LS2/3/4/7 + truck motors = Gen IV
Current Direct Injection LT1/4/5 + DI truck 5.3/6.2 (and 4.3 to be accurate) = Gen V
Regarding the lift plate, Gen 3/4 have the same valley cover bolt pattern. Possibly Gen V too but I have no direct experience so don't want to post the wrong info. In any event, Amazon has a few different LSx lift plates for like 50-60 bucks, here's the one I bought and am using for my current swap project:
Regarding the lift plate, Gen 3/4 have the same valley cover bolt pattern. Possibly Gen V too but I have no direct experience so don't want to post the wrong info. In any event, Amazon has a few different LSx lift plates for like 50-60 bucks, here's the one I bought and am using for my current swap project: https://www.amazon.com/Massive-Speed...0517719&sr=8-1
Without the trans connected itsi basically just the 2 motor mount bolts to yank, and then you can remove the engine. If the trans is still connected youd need to unbolt it from the trans crossmember.
Btw if you do pull the trans and flywheel/flexplate, put the flywheel bolts back in the crank as the holes aren't blind and oil will come pouring out when you tilt the engine. Ask me how I know, lol.
