Fuel Pump Help
So.... the question is, what am I supposed to be replacing? Some fuel pumps look completely different from the other...
Do I want this?
https://www.ebay.com/itm/1998-Camaro...-/382078029511
I thought they were a lot bigger than that with 3 lines (for like feed/return/evaporative pressure or something.) I'm going to pay a shop to do it, if they can (with the full custom exhaust in the way...). I'm not scared of hacking my car because of maintaining its "classic body", I'm scared of cutting near and playing with fuel. I have absolutely no idea what I'm doing here, and I feel like gas lines could easily send me to my wife if I **** up.
you just have to be really **** about vacuuming and wiping up all the dirt and metal shavings. Before you open up the tank.
Is it easy to figure out where to wire everything up? Should I pull the negative on the battery and then relieve fuel pressure somehow? I'm "noob" and super nervous LOL. Also, where is the FPR? I know on the LT1 it was on the back of the engine and was a huge pain in the *** to get to.
And then another question (sorry), is there some kind of foam insulation that isn't flammable or could I put some kind of cardboard or something in there to keep potential gas fumes from coming in to the cabin?
The regulator is in the pump assembly. Its the brass piece in the pic.
As you research this project and look through these links, be sure you are NOT looking at images/templates from a '99+ car. The '99+ cars need to be cut in a different spot, and if you follow the wrong template you will be very disappointed as it won't work for your '98. For example, the image posted above by jaxcam02 is for a '99+ car and NOT the correct cut location for your '98. However, the tool he posted in nice choice.
There are lots of images for the earlier cars as well, they need to be cut closer to the rear seat. I don't have any links handy at the moment, but there are plenty on this site if you do a search.
https://www.texas-speed.com/p-4357-r...-assembly.aspx
In 2006 on a trip to Florida,the pump died getting off I95. I had a spare pump along and 10/15 minutes later it was up and running. I carry spare 'stuff' along because of the extensive travelling. Called Summit back at the motel and ordered another pump which was delivered before I left back to Ohio.
But just so you know it's really not that difficult to do. Once you get over the low risk of flakes it's pretty straight forward.
First picture is measurements for 98's and the second picture is my trap door.
