Ls1 harness standalone
Hey guys what’s up. I’m doing my own standalone harness I’m about to solder the injector wires but I notice the coils are solder with the injectors in a junction would it be ok To leave them like that.
And my reverse lock up solenoid, skip shift solenoid, 02 bank 2 snsr 2, 02 bank 2 snsr 2 and maff sensor are together as well can some guide to the right direction please. Anyone that had done as ls1 standalone harness with a t56 trans let me know
The Coils and the injectors on each bank share a single fused ignition feed. INJ1/2 fuses
The MAF and the (Bank 1/2, Sensor 1) o2 sensors share a single fused ignition feed. Eng Sen fuse
Since you are building your own stand alone harness, you can wire it differently if you wish or leave it as is. The rear o2's are just for emissions and can be eliminated for a custom harness. I am unsure of the solenoid wiring, but I am usually working with manual cars.
Harness
Wouldn’t be any problem if Leave the coils with injectors connected or will be better if I Rewire the coils o n circuit. I did deleted the rear o2s but I switch the rears to the fronts on the ECM. Thanks for your help.
