How does the AIR system work?
Is the pump electric? Is it controlled by the PCM I assume? Where does it get air from?
If you are doing this swap you really need the factory service manual for the vehicle that's donating the drivetrain. With this, all you AIR questions would be answered.
Go check out helms. http://www.helminc.com/helm/homepage.asp
. Little LS1 Edit and no EGR, AIR, or Cats I can/will still pass emissions, ain't it great
I really don't think you will need the air system. Emissions tests are normally done with the car/cats properly heated, and proper editing will totally remove the code and still allow you to pass. Unless they pop the hood and do a visual to look for AIR/EGR (never heard of this) you won't need//want it.
That being said, I know that CA is a hotbed of hot-rodding. How do the guys that make custom rods deal with this? There must be some sort of exemption available. Whatever that is, it should allow you to transplant your engine, customize the exhaust, and remove AIR and EGR.
so basically my air system is good for nothing and once i get headers i cant use it anyway right? I know people have taken them off for weight reduction but i thought they did a little more than that.
