Exhaust from the cat to the muffler? Z28 1999
Hello does anyone now where i can buy the exhaust pipe that comes from after the cat where it gets to 1 pipe
to the rear muffler?
The pipe that comes from the front after the cat and is straight and then goes over the rear axle and in to the muffler.
Do i make any sense?
Mine has rust holes, but the rest of the exhaust is fine.
would be best if i could buy it in Europe since i am Swedish.
Thankful for your help!
I don't think there are any aftermarket parts that would be a direct replacement for just that section. It is one piece from the factory. I have only seen it come in several pieces as a kit from the aftermarket companies.
You can get an aftermarket "Cat-back" exhaust kit from several different vendors. I got mine from Texas Speed and Performance. Here's the link: https://www.texas-speed.com/p-5187-t...ess-steel.aspx This kit requires a little bit of custom fabricating/welding. It also does not come with hangers for the tips. You have to buy those separately, and weld them on.
