Not sure what it is? Need help
I have an unidentified engine and transmission.
The only anecdotal information I have is it is out of a 2014 Chevy Silverado, not sure that is the truth
Theses are the numbers I have off of the complete engine and transmission :
256132 stamped on the top RR of block
12560392 on oil pan
502 on right side of block
24208015-6 on tail shaft of transmission
42 3152 2334 on left side of transmission
53 on both heads
862 also stamped behind alternator, passenger and driver side of block.
I have no vin number to help with the identification. The motor/transmission is part of an investigation we are conducting.
Thank you for your time and effort in this identification
Steven Santor
12560392 on oil pan
53 on both heads
Steven Santor
Not sure when Chevy quit using the 862-706 heads. I think somewhere around 2004-5 when they went to VVT/DOD I think they changed to 799-243 heads. I may be all wet but it sounds like you might have a earlier model than 2014. Some one on here can probably do a better job than I with the dates ..
