Weird noise on engine, help!!
Old Sep 21, 2019 | 03:58 PM
harley909dd's Avatar
Default Weird noise on engine, help!!
So I finally got my engine swap running and now I get this knocking sound. Any ideas of what could it be?
Old Sep 21, 2019 | 04:03 PM
madmann26's Avatar
Start with taking the belts off. See if it still does it. That’ll eliminate the accessories.
Almost sounds like a rod but I would think it would do it from the start.
Old Sep 21, 2019 | 04:09 PM
Ok, I'll give it a try and see what happens
Old Sep 21, 2019 | 04:10 PM
Yeah it only does it when I give it some gas
Old Sep 21, 2019 | 05:24 PM
LLLosingit's Avatar
How is the oil pressure?
Old Sep 21, 2019 | 05:26 PM
Oil pressure is at 24 at idle
Old Sep 21, 2019 | 05:27 PM
Took the belt off and still makes that noise
Old Sep 21, 2019 | 09:15 PM
Majestic9C1's Avatar
clogged or sticky lifter??
Old Sep 21, 2019 | 09:34 PM
LLLosingit's Avatar
Can you give the back story on the engine, Did you hear it run prior to installing? Oil pressure is a little low if that's cold idle pressure. The reason for asking what the oil pressure was and if you heard it run prior to installing it is to help find the problem, It could be a lifter that hasn't pumped up, It's usually not a knock sound more of a tick.
